Do boxes need to be the same volume
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44173
Printed Date: May 13, 2026 at 2:33 AM
Topic: Do boxes need to be the same volume
Posted By: Clayd6287
Subject: Do boxes need to be the same volume
Date Posted: November 30, 2004 at 9:25 PM
i am makeing two separate boxes for my trunk. i molded them in, but what if they arent the same size in volume, but close. will it affect my sound.
Posted By: Alpine Guy
Date Posted: November 30, 2004 at 10:44 PM
technically yes it will, , ,fill the box's with packing peanuts, measure how much of a differnce there is, ,and in the bigger box put something in there to fill up space till there both equal.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: CarAudioHelp
Date Posted: December 01, 2004 at 12:51 PM
Not really, assuming a sealed enclosure that's within say 20% and using identical woofers.
Posted By: placid warrior
Date Posted: December 01, 2004 at 9:08 PM
and cant u use insulation to trick the box into thinking its bigger...therefore the ability to make 2 different boxes sound the same?
Posted By: noakes75
Date Posted: December 05, 2004 at 10:27 PM
ive tried useing poly fill to try and trick the subs and every time i blow subs. and thats the only time i do. any ideas? ------------- front leaning rest postion MOVE
