tryin to add another 15 to my system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47796
Printed Date: May 10, 2026 at 11:42 AM
Topic: tryin to add another 15 to my system
Posted By: dubb
Subject: tryin to add another 15 to my system
Date Posted: January 15, 2005 at 6:20 PM
im tryin to add another 15 to my system for a total of three and total SPL. i have priced custom enclosures in every car audio shop in my city and the prices are crazy. i wanted to get suggestions and info on building my first sub box. i took the measurements of my trunk and the subs would be able to fit in a squared hexagon shape. im not a expert wit carpetry but i have took a wood shop course. one question i do have is in the box i have now my subs are seperated by a wood wall. this is a purchased box. with the shape idea i currentyl have i dont think i would be able to install walls between every sub. it would jus be a box wit air space between subs. what do i lose, or pros and cons of these different procedures. please help....... ------------- 2005 Ford 500 SEL. 3 Kicker CVR 15"s. 2000 watt Quantum Audio AMP.
Posted By: supradude
Date Posted: January 15, 2005 at 8:08 PM
I would separate each sub, even if I had to cut the airspace a little to do it. If you will lose too much airspace it would be a bad idea to even try to go with 3 subs. (IF) you are going to run all 3 off of a mono amp you COULD do this. Personally I don't build them like this though.
------------- '85 Toy
Posted By: bluetruck
Date Posted: January 16, 2005 at 7:45 AM
SPL has a lot more to do with box design than # of speakers or really even the power of the speakers. i dont compete in SPL so i cant help you much with box design, bt i hope you can find someone who can help you before you waste money on new subs and be dissapointed at the 3dB gain of that new $300 subwoofer.
Posted By: Alpine Guy
Date Posted: January 16, 2005 at 10:30 AM
If you can't separate the chambers, at least go ported to help prevent the subs from fighting each other in that enclosure.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Date Posted: January 16, 2005 at 6:36 PM
If you can't separate the chambers for a sealed box I doubt you will have enough room for a ported box, unless you just use 2 subs in it. A ported box for 3 subs would be huge.
