dowels
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55380
Printed Date: April 06, 2026 at 5:03 AM
Topic: dowels
Posted By: lilbenny
Subject: dowels
Date Posted: May 08, 2005 at 9:57 PM
ive been making my sub boxes for the longest tiem.. im finally at the point where i mount my sub rings... the only thinks is that i cant seem to hold them up.. i read somewhere to use dowels and a hot glue gun but their not strong enough... i was going to resin them but i still need to fing out the sq ft measurements so i cant do that.. any suggestions?
Posted By: M&mfabrications
Date Posted: May 08, 2005 at 10:11 PM
What size dowel are you using? I have always had good look with that method using 1/2 inch dowels. How are your rings oriented while you are trying this? If you have them facing upwards toward the sky then you should be able to get by with using the hot glue method.
