after fiberglassing fleece, ring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56437
Printed Date: April 07, 2026 at 8:10 PM
Topic: after fiberglassing fleece, ring
Posted By: lilbenny
Subject: after fiberglassing fleece, ring
Date Posted: May 25, 2005 at 8:07 PM
after you fiber glas the fleece how do you get your perfect circle again? i f'ed up quiet a few times i routered most of it out... then i made some boo boos so put boddy filler and hoping it will come out nice lol.. just curious how you pros do it lol
Posted By: Velocity Motors
Date Posted: May 25, 2005 at 8:58 PM
Use a router with a flush bit to cut away the fiberglassed fleece that is on top of the MDF ring.
Posted By: j68rh
Date Posted: June 05, 2005 at 8:44 AM
i used a dremel to cut away the fiberglassed fleece away from the opening of the mdf ring
Posted By: Alpine Guy
Date Posted: June 05, 2005 at 9:31 AM
Be shure to cut the fleece in the center of the sub opening where you didn't resin with a knife first.  If you get the fleece spun around your router it can be very dangerous.
