b quiet odor?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59690
Printed Date: April 07, 2026 at 1:26 AM
Topic: b quiet odor?
Posted By: gsr.sedan
Subject: b quiet odor?
Date Posted: July 19, 2005 at 4:50 AM
I've never used b quiet before, and I'm planning to install b quiet in a large cargo van to reduce the road noise.  I have to work inside of this van and I'm wondering about the rubber/tar smell?  I'll be using at least 100 sq feet and the roof and most of the sides will be exposed b quiet.
Does the rubber smell go away with time?
Thanks,
Dave
Posted By: nowlater123
Date Posted: July 19, 2005 at 10:35 PM
The smell will dwindle over time, but because it a an oil based substance, it will never dry to the point where it wont emit an odor. Give it some time, and the smell shouldn't be as noticeable.
I would suggest using some sort of non-porous material, plastic, to cover the stuff, and this will greatly cut down on smell.
Kenwood all the Way!
Posted By: swede
Date Posted: July 20, 2005 at 8:11 PM
I used eDead and although it had very little odor, I used additional adhesive that added some smell. When I sealed the seams with duct tape, what little there was, was totally gone - night and day.
Subtlety is EVERYTHING.
Date Posted: July 21, 2005 at 4:26 PM
Will it stay on roofs?  Someone said that you had to use dynamat for roofs because of the heat.
Posted By: swede
Date Posted: July 22, 2005 at 8:14 PM
The roof was the primary area I used the extra adhesive and only did it after I did a test area and noticed it got loose after 3-4 days when super-heated (typical summer in Ohio - hot humid and miserable) - plus the car is black. After I added the extra adhesive it stayed tight with no problems.
eDead also has a paint they recommend for roofs (I still used the sheets though).
Posted By: TCalYen
Date Posted: July 22, 2005 at 9:24 PM
I have 250 ft3 of BQuiet Extreme in one of my vehicles and there was no odor at all.
