tweeter pod in a pilar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61029
Printed Date: May 15, 2026 at 11:47 AM
Topic: tweeter pod in a pilar
Posted By: adix5689
Subject: tweeter pod in a pilar
Date Posted: August 09, 2005 at 8:41 PM
I just made a tweeter pod . I super glued the tweeter pod to the a pilar. Then I super glued the micro fleece to the a pilar. Covered a fleece in fiber glass resin. I waited until it harden . I then used duramix 4040 to secure the edge of the fiberglass tweeter pod enclosure to the a pilar plastic. MY problem is that the duramix 4040 didn't stick to the plastic a pilar. I applied the duramix with the mixing gun. I let it harding for  over an hour before I touched it. I have used duramix before and it bonded to the plastic. Does antbody know of any other type of plastic adhesive I can use.
Posted By: rhdAndy
Date Posted: August 09, 2005 at 10:52 PM
you can probably do it with urathane, that crap sticks to anything and takes hellla lot of work to get it off, also hzemall.com sells liquid pastic that should bond the two< =text/>
Posted By: adix5689
Date Posted: August 10, 2005 at 4:08 PM
I used duramix 4040 its a urathane and it didn't stick.
