Tips wanted for making trunk floor cover
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61206
Printed Date: May 14, 2026 at 10:29 PM
Topic: Tips wanted for making trunk floor cover
Posted By: kosoku
Subject: Tips wanted for making trunk floor cover
Date Posted: August 12, 2005 at 9:16 AM
I need some ideas on what materials to use to make a spare tire/trunk area cover for my hatchback mustang.
I have the battery in the middle of the spare well (in a battery box with compound curves on the corners).  I asked a while back and someone suggested just stretching some fleece and hot gluing it to the battery box and the surrounding sides of the trunk area. However, I'd like something a tad bit stronger and I have been thinking of using foam.
How expensive would the foam material be, and is Home Depot the best place to get it? It seems like a good choice because I can cut and shape it easy, and it is lighter than say, MDF. I am lousy at working with wood so I would like to stick with primarily glass/foam.
Posted By: 5150azn
Date Posted: August 12, 2005 at 11:52 AM
I don't know what your really trying to do but, I suggest using cardboard or like 1/4" wood. Foam seems like it would be kinda hard to shape plus it won't hold it's own shape too well.
Tell the Snap-On guy I'm not here!
Posted By: mi_what
Date Posted: August 12, 2005 at 1:04 PM
I find that Foam sucks to work with. If it's not too big of an area you can probably use the foam blocks found in the linen/arts and crafts section at wal-mart (that's what I use) but, with any foam you have to make sure you cover it with like three layers of tape and two to three layers of aluminum foil or else your mold will be deformed...that's why I hate working with it. Anyway, Wally world sells it for like 5 to 6 bucks for a pretty big block. If you want something stronger go with MDF like 5150azn said or just add some glass to the fleece afterwards. If you don't want to bother with the glass, just fleece it, cover it with the "miracle mixture" and sand. That's what I did with my center console and it came our VERY sturdy.
Posted By: fr33w0rld
Date Posted: September 14, 2005 at 12:19 PM
go with some low expansion spray foam...u can use 220 sand paper to mold it how  ever u want..and the glass on top and make your creation come alive...we did my buddies 240 sx trunk up like that with a 15 and 2 amp holders on each side
HU Alpine CDA-9855 Amp MA Audio 802sx 4,400 RMS 1 ohm Sub 18" MA Audio RMS 5,000 @ 1.5 ohm Ported Box Car 99 civic Si
Posted By: Teamrf
Date Posted: September 14, 2005 at 8:09 PM
Use thin board..and make stilts for them to support it.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: abovestock
Date Posted: September 15, 2005 at 1:50 AM
https://www.alpine-usa.com/
Check out alpine's show cars. They use an MDF shaped skeleton to make the underside and then glass over it. They did this on all three of there cars so far and show step by step in detail how it was done. Check this out for some inspiration, I know it helped me I hope it can help you. Good luck.
