Twin Sub FG Box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61752
Printed Date: May 14, 2026 at 5:42 PM
Topic: Twin Sub FG Box
Posted By: JeremyJustSaid
Subject: Twin Sub FG Box
Date Posted: August 20, 2005 at 6:09 PM
posted_image
This is the frame, still needs to be rounded off. On the left the sub will be facing you but angled up a bit. The sub on the right will be facing to the left angled up also. Im just waiting for the rings to come in that i ordered. Any suggestions on what you guys would have done? What you would do next? Should i add a port or keep the thing air tight inside?
Posted By: mi_what
Date Posted: August 20, 2005 at 7:50 PM
Is that particle board??? why didn't you use MDF? I'll be honest and tell you that I am having a little bit of trouble figuring out what you are making posted_image I think it will become more clearer when you add the rings and the fleece. Off to a good start as of now though; I can see you got your braces in there.
Date Posted: August 21, 2005 at 1:44 AM
Thats mdf...i know its a littel hard to understand, when i get the fleece on there youll see what im saying..i guess just wait till about tuesday to reply to this thread sorry i started it so early....
Posted By: mi_what
Date Posted: August 21, 2005 at 9:50 AM
No, I was probably the only one who couldn't see it. Just be sure to post pics when you get the rings in and stretch the fleece. I really am looking forward to seeing what it is I am looking at. I guess it's just the resolution on your camera or the way it loaded that makes it look like particle board.
Posted By: blufab
Date Posted: August 21, 2005 at 12:52 PM
if you have the time maybe you can draw some rings in your picture witha paint program, to give an idea of what you are tryin to do.
Posted By: auex
Date Posted: August 21, 2005 at 1:50 PM
JeremyJustSaid wrote:
Thats mdf...
There is no way that wood is mdf.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: rhdAndy
Date Posted: August 21, 2005 at 5:11 PM
if its anything right now it looks like a piece of abstract art.< =text/>
Posted By: customcarchris
Date Posted: August 21, 2005 at 10:34 PM
That really doesn't look like MDF, make sure you have the right stuff before you get too far, because if particle board gets wet it will swell and then fall to pieces. It is also not nearly as strong as MDF so be careful if this structure needs to be pretty solid.
Posted By: placid warrior
Date Posted: August 22, 2005 at 12:34 AM
thats definately particle board...if it was the resolution on the camera the piece of paper would look like it was made of paper chunks and everything else would be unrecognizeable.  If the guy at the store told u that was MDF u should get him fired. It looks like he inteds to fleece the entire project when he gets the speaker rings wich will mean that both subs are not divided and they share the same port, or i could be wrong and the big base piece is for a flat floor or something.  If u want some advice and can handle some criticising than good on u and you'll end up with a better quality project in the end, if u read these and take them as flames and leave the forum then u wont learn and will continue building half-*** projects (not saying its half ass yet except for the particle board as i dont yet understand fully how the box will be going together.  What is this going in?  i would get rid of the port and just make the boxes sealed though untill u get some more knowledge on building ported boxes.
Posted By: abovestock
Date Posted: August 22, 2005 at 2:21 AM
Please be sure that is MDF. The rings I sent you are MDF, so please compair them and be sure you know what you are using.
Date Posted: August 22, 2005 at 7:47 AM
sux being noob...
Posted By: shark_2003
Date Posted: August 22, 2005 at 10:36 AM
Im pretty sure thats particle board
Posted By: One_Dieu
Date Posted: August 22, 2005 at 11:20 AM
JeremyJustSaid
I don't want to jump on your sh*t, but as a noob... myself I feel that I have to look out.  Looks like you have something great up and coming.  On thing I can tell you is make sure you base is solid and right becuse you will spend more money in the end trying to fix/save a project that started out foxed up.
Respect the Blood Line
Date Posted: August 22, 2005 at 3:31 PM
alright i got the right wood, glad im off to a rough start...I guess i just dont know my wood...but i promise i will have a nice fg box when im done
Date Posted: August 22, 2005 at 7:14 PM
posted_image
Ok so now what do you think....?
Rings where made by abovestock thank you verry much!
Posted By: JoeMetal
Date Posted: August 22, 2005 at 7:35 PM
That looks awesome, <b>JeremyJustSaid</b>. Good luck with it.
Date Posted: August 23, 2005 at 12:03 PM
looks muuuuch better.  Is it just me or do both rings look like they're the same size (is the bottom ring bigger so u can sit a sub in it and the top ring smaller so it goes around the outside of the sub) check the rings, if u have subs test out the rings by placing the subs in.
Date Posted: August 23, 2005 at 12:51 PM
yeah its same size....i know what your sayin...wasnt thinkin when i ordered them...damn
Date Posted: August 23, 2005 at 12:53 PM
posted_image
posted_image
posted_image
Posted By: JoeMetal
Date Posted: August 23, 2005 at 3:03 PM
Looking good.
Date Posted: August 24, 2005 at 1:26 AM
that is going to look sweet. Can't wait to see the finished project. Also thanks for keeping us all updated with lots of good pictures.
Posted By: 05honda
Date Posted: August 24, 2005 at 11:04 AM
off to a great start.......
