Door Panel Insert Mold Suggestions.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70828
Printed Date: April 03, 2026 at 5:18 AM
Topic: Door Panel Insert Mold Suggestions.
Posted By: TCalYen
Subject: Door Panel Insert Mold Suggestions.
Date Posted: January 15, 2006 at 11:08 AM
What's up all...
Take a look at this door panel.  Basically what I'm going to do is make inserts that fit into the taped off area.
https://www.tcalyenindustries.com/tcalyen_files/626/panel1.JPG
posted_image
I literally just got done taping this panel.
I'm trying to figure out how I should make it.  Here is what I was thinking.
1. Using spray glue to secure fleece to the insert area, resin, bondo, and paint.
* The insert doesn't have to be strong at all.
2. Using spray glue to secure mat to the insert area, resin, bondo, and paint.
Basically, fleece or mat.  What do you think.
TCalYen
Posted By: bellsracer
Date Posted: January 17, 2006 at 4:47 AM
How much sanding are you willing to do? I probably would go fleece since you are just making simple inserts
Posted By: Velocity Motors
Date Posted: January 17, 2006 at 7:43 AM
Seeing that it's just it's just inserts, I would go directly to fiberglass matting and resin ( about 3 layers ) & then use small amounts of bondo to smooth it out.
Posted By: TCalYen
Date Posted: January 17, 2006 at 9:04 AM
Thanks Jeff,
That's what I decided to do.  Just using the fleece would have resulted in damaging the insert when I removed the mold.
TCalYen
