Gallon of FG, approx. Area coverage?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80025
Printed Date: May 12, 2026 at 6:48 PM
Topic: Gallon of FG, approx. Area coverage?
Posted By: spikedout
Subject: Gallon of FG, approx. Area coverage?
Date Posted: July 07, 2006 at 6:55 AM
Hey everyone, this is my first time on the forums and i've been looking everywhere for a post about how much area a gallon of FG will cover when glassin an enclosure?
I want to start my own project and I am trying to figure out materials and an approximate cost... if anyone could help me that would be great!
Posted By: Melted Fabric
Date Posted: July 07, 2006 at 10:46 AM
A gallon of fiberglass?
Do you mean, a gallon of resin for fiberglassing?
If that is the case, for the average box, I'd say a little over a quart (25% of a gallon) would do the trick, then again, it depends on just how large or small your enclosure is.
What are the dimensions of what you are building or want to fabricate?
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
Posted By: crazyoldcougar
Date Posted: July 07, 2006 at 8:02 PM
it also depends on how many fiberglass projects you wish to tackle...it is considerably cheaper to buy your resin by the gallon...but if your only going to do one project or two then it is better to get it by the quart...resin has a self life and will tend to go nasty on you if left un attended for too long..
also it is cheaper to buy your mat off the roll rather then in packages
Fiberglass Guru.
Posted By: jlord16
Date Posted: July 08, 2006 at 4:11 AM
Typically 1ltr of resin is used with 1 metre square of matting
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
Date Posted: July 08, 2006 at 1:17 PM
Oh wow, it seems to cover alot more area then I thought.
Here is the drawing of what i want to do. Only the front panel will be fibreglassed because i want to change the angles of the subs, the outside subs will face inward a bit, and the middle sub will be angle'd upwards.
I am also wondering, will I need to support the subs from inside? (something underneath holding them up to relieve stress on the front end?) What do you suggest?
https://www.filelodge.com/files/hdd4/80791/speakers.gif
posted_image
Posted By: sawhit4
Date Posted: July 08, 2006 at 1:28 PM
My box was similar to yours, and no i didn't use anything to support the sub from the inside.  Just make sure you use plenty fiberglass mat especially around where the sub rig attaches to the box.
Posted By: killer sonata
Date Posted: July 08, 2006 at 2:04 PM
Thats a pretty sweet desing. My only suggestion would be to maybe think about angling the outer subs outward instead of inward. Inward subs might cancel each other out.
"People with mullets live 40% longer"   - Ricky Bobby
Date Posted: July 08, 2006 at 7:19 PM
sawhit4 Would you be able to post pics of your box?? Im curious to see anything similar.
Date Posted: July 10, 2006 at 9:57 AM
How much will you be putting through your setup? (watts?)
Date Posted: July 10, 2006 at 12:08 PM
Out of this box i will be running
1 - PDX-1.1000watt Alpine Digital Amp
3 x 10" Alpine Type-R 1042D subs
I listen to alot of electronic music with fast snappy bass... so i figured 10's would provide the tight bass I require.
Date Posted: July 10, 2006 at 12:21 PM
since type Rs can handle 500W RMS I would recommend only getting 2 instead of 3. 3 type Rs will be underpowered off of that amp. That is a sweet amp by the way. My budyy has one and its amazing.
Date Posted: July 10, 2006 at 1:15 PM
Yea, was going to mention that too. It would defeat the purpose if you lacked power if all three of them are to contribute to the good vibration.
