Fiberglassing dash
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80364
Printed Date: May 13, 2026 at 9:04 PM
Topic: Fiberglassing dash
Posted By: dan476
Subject: Fiberglassing dash
Date Posted: July 16, 2006 at 7:58 PM
hey guys, I got an old dash that is in pretty bad condition, got a lot of cracks and is a little bent because of cracks. could you tell me what would be the best way to fiberglass it? should i use some sort of foam to plug up the cracks and also when surface is uneven (one side looks like it has a dip in it) what should i do to even it out?
posted_image
posted_image
posted_image
~Dan
Posted By: dan476
Date Posted: July 16, 2006 at 8:15 PM
sorry computer double posted this one, please delete
~Dan
Posted By: Melted Fabric
Date Posted: July 17, 2006 at 12:21 PM
When you fiberglass it, how do you want it to look after you are done?
Will you be making a copy of your current dash and do it in fiberglass?
Are you making a fiberglass "cover" for your dash?
Or... Are you just trying to correct those cracks and keep your dash looking the same?
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
