Bandpass box dimensions for a kenwood sub
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81346
Printed Date: May 15, 2026 at 2:26 AM
Topic: Bandpass box dimensions for a kenwood sub
Posted By: gezzy
Subject: Bandpass box dimensions for a kenwood sub
Date Posted: August 08, 2006 at 4:09 AM
Hi, i have a kenwood KFC - W3003 subwoofer and i would like to put the sub into a bandpass box, i have searched the internet and many different forums for recommended bandpass enclosure dimensions but havent been able to find any, can anyone help? Thanks
Posted By: josh1979
Date Posted: August 08, 2006 at 4:40 PM
kenwood does not list  the thiele small parameters for this woofer on there site.contact them at the link below. to design a proper band pass box we will need to know
Fs.
Qts.
Vas.
with these parameters i can help you with a simple 4th order band pass box
https://www.kenwood.com/cgi-bin/inter_contact.cgi?country_form=1&default_address=%3CB%3EKenwood+Corporation%3C%2FB%3E+%3CBR%3E2967-3%2C+Ishikawa-machi%2C+Hachioji%2C+Tokyo+%3CBR%3E192-8525%2C+Japan+%3CBR%3ETEL%3A+81%28426%2946-5111%3CBR%3EFAX%3A+81%28426%2946-7960%3CBR%3E&default_email=info@kenwood.com&mailto_others=info@kenwood.com&country=South+Africa&x=17&y=12
bring back the rotary phone so i dont have to press 1 to proceed in english
Posted By: gezzy
Date Posted: August 10, 2006 at 3:46 AM
hi, kenwood emailed me with the following specs for a bandpass box...
Bandpass enclosure for KFC - W3003 subwoofer,
rear chamber 2.64cu ft,
front chamber 2.0cu ft.
Port diameter of 4 inches, lenght of 6.2 inches
QTC=n/a, F3 is 27/70Hz, do not use fill/dampening.
can someone help me with the actual dimensions so i can start cutting wood :)
thanks
Posted By: josh1979
Date Posted: August 10, 2006 at 8:49 AM
what are you putting this box in to ( car -suv - hatch back ) becaust it is going to be huge the simpleist build would make the box 56.75 / 12.75 / 12.75 that will give you a total of 4.66 cu.ft
Posted By: gezzy
Date Posted: August 10, 2006 at 4:26 PM
Hi josh, the box is going into a E36 BMW, space isnt a issue :)
Posted By: josh1979
Date Posted: August 10, 2006 at 4:55 PM
i need the over all diameter of you woofer and than i will design you cut sheet
