Components and Sub in door?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86908
Printed Date: May 05, 2026 at 12:01 AM
Topic: Components and Sub in door?
Posted By: datspeed77
Subject: Components and Sub in door?
Date Posted: December 09, 2006 at 12:26 PM
Guys,
I'm planning on putting some components and a six inch sub in each door.  Question is would I get destructive interference if I had the coponents and subs in the same enclosure?  What do you guys think?  Thanks for any input.
Posted By: sound station
Date Posted: December 10, 2006 at 7:45 AM
i think put 2 subwoofer 8" under front seat if posible.
Posted By: bballguy162006
Date Posted: December 11, 2006 at 4:01 PM
To answer the question:
I don't think that it would distort.  It should be the same as putting 2 subwoofers in a single chamber enclosure.  But I could be wrong...
Posted By: alphalanos
Date Posted: December 12, 2006 at 7:56 AM
You dont want to put them in the same enclosure. Try to make separate chamber for each then youll be ok. The air from the 8" will distort the 6.5 or whatever it is youre using.
Posted By: layzboy
Date Posted: December 13, 2006 at 1:26 AM
First, what exactly to you mean by 6 inch sub...do you mean just a midbass driver? or are you actually going to cross it over below 200Hz to make it a small subwoofer?
Date Posted: December 13, 2006 at 12:35 PM
I'm putting in the 6w0 JL sub.  It will be playing 80 lowpass.  I know (normally) you wouldn't want to put sub bass and components in the same enclosure.  But, because it is a six, I'm wondering if it would distort the components due to the subs making the components act as a port?  Due to the contours of the door panel, I wanted to save some time by putting them in the same enclosure.
Posted By: maliboom
Date Posted: December 19, 2006 at 6:44 PM
The sub would make the components move more to the bass than they would naturally. You would be better off to add a simple divider between enclosures. For the time it will take to make the enclosures seperate will be alot less than ripping it apart and redoing it.
Posted By: maliboom
Posted By: killer sonata
Date Posted: December 19, 2006 at 9:11 PM
no, you dont want them in the same enclosure. you can move the component woofer to the kickpanel and leave the 6W0 in the door or you can use a foam baffle with polyfill on the inside for the subs enclosure. that is what I did with my 6W0 in my doors that I had. here is a link.
https://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-788
Date Posted: December 21, 2006 at 1:52 PM
Good idea killer sonata!
Date Posted: December 21, 2006 at 3:52 PM
I would put the components in the kick, but there's no space on my kick to do so.  I like the idea of the foam baffle but I do have enough space for building an entire enclosure.  I guess I'll have to build a chamber for the components, thanks for the input.
