Router bits
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8766
Printed Date: May 16, 2026 at 12:09 PM
Topic: Router bits
Posted By: messiah9966
Subject: Router bits
Date Posted: January 29, 2003 at 11:16 AM
what type of router bit are you using to trim the fiberglass from the edge of the speaker baffle? Can you use this bit with an air drill?
R. CLARK
Posted By: sickstyles
Date Posted: January 29, 2003 at 3:17 PM
 Id use a laminate cutting bit, you can get one from a home depot or any other home supply store. As for using an air drill, i wouldnt. Most router bits spin at 22-24,000 rpm, not spinning the bit fast enough will ruin it. You can also use a grinder to take off the extra glass as well. goodluck
andy
Posted By: audiomechanic
Date Posted: January 29, 2003 at 10:43 PM
what I do for the insides of my speaker rings and the sides of the boxes , is use a flush cut laminate bit in my die grinder...this will allow you to get in tons of places theat you cant get with a router...but be careful not to get too much of and angle, or let it get away from ya ......installguy509
Date Posted: January 30, 2003 at 11:16 AM
thanks again installguy509
R. CLARK
