Rage filler over Bondo?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88228
Printed Date: April 29, 2026 at 5:37 AM
Topic: Rage filler over Bondo?
Posted By: ricoshay
Subject: Rage filler over Bondo?
Date Posted: January 02, 2007 at 2:23 PM
Does anyone ever use a "base layer" of Bondo first before applying a higher quality filler like Rage .  I just thought it would save a lil money.  Any problems that could arise? (chemical, sanding, quality)
Posted By: Velocity Motors
Date Posted: January 02, 2007 at 2:55 PM
I can't see there beign a problem with using Bondo first then Rage afterwards. Just make sure that you only sand the base coat to a 36 grit finish so that the Rage has something to bite into.
Posted By: ricoshay
Date Posted: January 02, 2007 at 3:06 PM
good advice to remember.   Besides, I definattely don't want to sand Bondo anymore than I have to anyways!
