door deadening and sound foams
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92163
Printed Date: May 14, 2026 at 1:37 PM
Topic: door deadening and sound foams
Posted By: bkoepp2
Subject: door deadening and sound foams
Date Posted: March 26, 2007 at 10:05 PM
My question is how do you attach the closed cell foam to the inside of the door...
If you put a layer of foam into the door you'd need some type of adhesive so it doesn't get caught up when rolling the windows up and down. Also, I'm in the midwest so I'll be seeing in-car temps ranging from -30 to 130F.
I've never seen this discussed so I had to ask before I deaden my doors next week. I have a 2 door Grand Am and those things are huge. I'll be doing a layer of Raamat or Second Skin with one (or two) thick layers of closed cell. I've done a lot of reading but any advice is appreciated.
Posted By: bkoepp2
Date Posted: March 26, 2007 at 10:31 PM
Wouldn't a thicker foam make more sense, or is density the key? Is there some sort of "rating" on these products? I'd imagine I could get some of the thicker stuff like below:
https://www.partsexpress.com/pe/pshowdetl.cfm?Partnumber=260-515&raid=54&rak=260-515
3 sq ft for $6.65 2.5" thick
Or do the more thin, which would be easier to install but I find it hard to believe it does an equal/better job than the thick.
https://www.secondskinaudio.com/cgi-bin/index.cgi?pg=3&p=ps
9 sq ft for $11.98 .125" thick
https://www.raamaudio.com/cgi-bin/index.cgi?p=pr
42 sq ft for $11.96 .125" thick
Posted By: bkoepp2
Date Posted: March 26, 2007 at 10:36 PM
My mistake, the pe stuff is open cell. Is there a thick, yet affordable option?
Posted By: turbeau69
Date Posted: April 12, 2007 at 8:50 PM
