Speaker Rings?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9624
Printed Date: May 16, 2026 at 4:05 AM
Topic: Speaker Rings?
Posted By: emorse2323
Subject: Speaker Rings?
Date Posted: February 16, 2003 at 9:21 PM
When you make speaker rings do you have them out of 3/4 MDF and then use a piece of 1/2 MDF on top of that only bigger to make the speaker flush?? Or how do you guys usually do it?
Posted By: auex
Date Posted: February 16, 2003 at 10:19 PM
That sounds about right. You would just make two rings the same size external diamater then cut the mounting ring to the mounting diameter of the sub and the flush ring to the external diameter of the woofer. If you were going to use a grill you would just make the flush ring out of 3/4 mdf.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: audiomechanic
Date Posted: February 17, 2003 at 6:11 AM
to cut those rings out , use a router and a circle jig.
you can use a jigsaw and a compass but most of the time it will come out wavey and need to be sanded.....installguy509
