confirmation for a box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97054
Printed Date: May 13, 2026 at 3:59 PM
Topic: confirmation for a box
Posted By: extacy
Subject: confirmation for a box
Date Posted: September 11, 2007 at 1:54 PM
Tomorrow im supposed to make a box for a friend of mine who has a Kicker Comp 12
The box will be 2.0cuft and the port will be tuned to 36Hz with a 3" diameter port with a length of 5" (thats what the port calculator here gave). I cant find a 4" diameter port sadly so im stuck with this 3"
Experts here think this will be good ? Anything I should change ? Thanks :)
Posted By: extacy
Date Posted: September 12, 2007 at 4:42 AM
Anyone please :(
Posted By: jmelton86
Date Posted: September 12, 2007 at 4:50 AM
As long as 2 cu. ft. is in the range that Kicker recommends ported for the Comp12, you should be good.
Make sure it's well-braced, solid, and leak-free.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Posted By: extacy
Date Posted: September 12, 2007 at 8:58 AM
Yes ... infact I was reading one of the older model manuals ... and they use this box size along with a 36Hz tuned port (4" though) so I guess this is good to go.
I wana ask one thing though ... what about adding two ports ? Is there anything I have to take in consideration when adding the second port (identical size/ tuning frequency) except for the additional port volume ?
Date Posted: September 12, 2007 at 6:10 PM
I wouldn't know that. But if the12volt.com's calculator gave you 5" for the port lenth based on 3" diameter, 2 cu. ft, and 36Hz then I would just use the one port.
Big3 in 1/0G
1/0G to GTO14001
Posted By: bellsracer
Date Posted: September 13, 2007 at 1:11 AM
Well what does the manual say? If you don't have it, kicker.com has the information there for you. Can't go wrong with that. ^-^
Ganbatte Ne!
Posted By: extacy
Date Posted: September 15, 2007 at 8:03 AM
Ahhh bellsracer you helped me out before too.
Anyways I got the Kicker running ... pretty satisfactory result :) Also got a nice L5 running in a Toyota Yaris ... sealed.
Next up is a W1v2 12" for my ownself. Ill post pics up of all the setups I hav been doin these days once all are done.
