manipulating enclosure volume
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97903
Printed Date: May 12, 2026 at 11:39 PM
Topic: manipulating enclosure volume
Posted By: john43
Subject: manipulating enclosure volume
Date Posted: October 12, 2007 at 12:34 PM
i am going to build a fiberglass enclosure to fit part of my trunk, but how do i build it to specifiations? im building it to conserve space, not just to look cool. should i build the box trying to make it a little big, then just measure it with packing peanuts and displace the volume with mdf? i really have no idea what to do here. also, what is the benefit of using kevlar? (assuming money is no object) do i need a different kind of resin? can i use less kevlar vs fiberglass? thanks for the help
Posted By: boogeyman
Date Posted: November 03, 2007 at 6:33 AM
that is correct build a little bigger...calculate volume with packing peanuts ..i use popcorn kernals a little more accurate add mdf in form of bracing (to kill 2 birds with 1 stone) until correct internal volume is achieved...as far as kevlar never worked with it ....
Posted By: john43
Date Posted: November 03, 2007 at 11:28 AM
Thanks, i read to use bean bag beans too, we'll see what is readily available when the time comes. i might be doing it on sunday so it will be an adventure. thanks for the help
