Nokia CK-7W Bluetooth Mute Speaker Output
Forum Name: Cellular and Communications
Forum Discription: Cell Phones, Hands Free Kits, Bluetooth, Two Way Radios, CBs, Pagers, Wireless Internet, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63777
Printed Date: May 12, 2026 at 6:49 PM
Topic: Nokia CK-7W Bluetooth Mute Speaker Output
Posted By: ewinkley
Subject: Nokia CK-7W Bluetooth Mute Speaker Output
Date Posted: October 04, 2005 at 12:21 PM
I just installed a CK-7W into my '03 4Runner.  With the factory stereo (which is "non JBL") I found out how to mute the stereo for in/outbound calls.  For those who wish to do this, email me and I will share.
However, I would like to get the audio output directed to my front speakers instead of the stock speaker that comes with the Nokia kit.  I have a wire that plugs into the speaker out of the Nokia, that I spliced and connected to the right front speaker and it works - the stereo is muted on a call, and I can hear conversation out of the right front speaker.  However, the sound level is not sufficient for when I am driving.  Anyone know of an amp or something that would increase the volume of the stereo?
Also, does anyone know of any decent auto stereo/CD systems that support both the mute and audio output via speakers function?  I went to about five different "audio specialists" stores, and they looked at me like I was speaking French.  They had no idea what I was referring to and had never heard of these features.
I know Blaupunkt makes stereos with a specific phone mute wire, and when on a call, the display has PHONE and the CD pauses to boot.  However, no where do I see any stereos that have phone audio input.  thanks for all replies.
Posted By: Customautomotiv
Date Posted: October 08, 2005 at 9:50 PM
No stereos that I have seen at this time offer a secondary line in to play over the sound sytem when the stereo is muted. The best you could probably do is use an auxillary line...when the stereo mutes you will have to push the aux button on the stereo and then it woul feed through your speakers......but its a pain in the ass. some factory system like audis and volkwagons actually have phone lines in where you can hook up the speaker output from your car kit. I did this on a toureg and it worked like factory.
Posted By: hafr
Date Posted: October 09, 2005 at 9:12 AM
I was just Speaking to a distributor of mine and they said that Parrot will have a AM/FM CD bluetooth deck next year.
Internally it will mute the radio and give you caller ID on the screen along with your phone book and seperate volume control for the phone. It will have speaker level output as well as RCA front and rear. I guess CES will have some more content for this years show.
Rich
Rich Hawthorne
Hands-Free installations
"don't talk with your hands full"
516-no-hands
Posted By: installer_nz
Date Posted: December 06, 2005 at 1:40 PM
Hi there, some VDO Dayton head units have this function as do some Blaupunkt units. Otherwise you can use a 3x relay setup where you use 1 relay to turn off the head unit and the other two to disconnect the speakers from the headunit and then connect them to the speaker output from the CK-7W. We do this all the time and it works like a dream, as long as you use a small PCB style relay that has dual contacts for each speaker you connect. The specs for the relay we use are:
5 AMP DPDT
COIL CURRENT: 30MA
CONTACT RATING: 5AMP
RATED VOLTAGE: 12VDC
COIL RESISTANCE: 400OHMS
POWER CONSUMPTION:360MW
NO/NC CONTACTS
Posted By: roan65
Date Posted: December 11, 2005 at 11:54 AM
Installer_nz:
Does the hands free signal need to be amplified in order to be hear at a decent volume?
Date Posted: December 11, 2005 at 10:54 PM
no it doesnt have to be amplified.
