VHF in 2005 Cavalier
Forum Name: Cellular and Communications
Forum Discription: Cell Phones, Hands Free Kits, Bluetooth, Two Way Radios, CBs, Pagers, Wireless Internet, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83548
Printed Date: May 08, 2026 at 9:05 AM
Topic: VHF in 2005 Cavalier
Posted By: slaymor
Subject: VHF in 2005 Cavalier
Date Posted: September 30, 2006 at 2:46 PM
I am trying to install my VHF, I use on the fire dept, into my 2005 Cavalier. I had it installed in my old car without any problems. Howver I'm not to sure how to install in the Cav. Everything is mounted and all wires are run. SHould I connect directly to the battery as my Hyundai or connect through the fuse box. Regardless I'm not sure how to do either. The battery itself has no place to connect to because it's all prewired and I have no idea how to connect it through the fuse box. Any help would be greatly appreciated. Thank you!
Posted By: sparkie
Date Posted: October 01, 2006 at 8:28 AM
You can connect the battery wire for your VHF to the main power input to the underhood fuse box next to the battery. There you should find an 8 gauge cable from the battery to the fuse box attached with a bolt. Install an inline fuse holder close to the fuse box. For ground, you should attach to a section of the body inside the car that is clean and free of paint. There is a flange of painted steel that the steering column mounts to that would be good to use. Scratch away the paint and screw in your ground wire. If your radio requires an accessory turn on, use the thich brown wire coming from the ignition switch. It is the accessory wire. You can find it in a thick section of split loom above the driver's kick panel. This connection should also be fused.
sparky
Posted By: elicoleman
Date Posted: October 05, 2006 at 1:03 AM
The last system I installed like this had only power and ground. I connected power to the 12v iginition (brown) in the steering column. I grounded using a grounding block. If you connect the power straight to the battery it will drain the system if you don't shut it down every time. Make sure you fuse.
2003 GMC Yukon, Kenwood 815DVD w/ Nav. Memphis speakers. Kenwood 1200W Amp, Alpine 400W amp. Rear view camera, headrest monitors. Parrot CK3100
