HF850 in 2007 Avalanche
Forum Name: Cellular and Communications
Forum Discription: Cell Phones, Hands Free Kits, Bluetooth, Two Way Radios, CBs, Pagers, Wireless Internet, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86323
Printed Date: May 07, 2026 at 7:43 PM
Topic: HF850 in 2007 Avalanche
Posted By: Ppagliai
Subject: HF850 in 2007 Avalanche
Date Posted: November 28, 2006 at 9:25 AM
Hi Folks,
Newby here...was wondering how to determine mute wire in 2007 Avalanche stereo wiring harness?    Also, is there any issues as far as where you pickup power to run HF850?
Thanks!!
Posted By: integratyper934
Date Posted: December 26, 2006 at 1:35 AM
is the hf850 a bluetooth? if so just interupt the amp turn on or if the ampo is signal or data sensing then cut the main power to the amp.
Posted By: Customautomotiv
Date Posted: January 05, 2007 at 10:28 PM
There is a harness available for it...u get radio mute and Sound through the audio system.
Date Posted: January 05, 2007 at 10:33 PM
where are you getting those harness'? i think its a cool idea except that if your job comes in you wanna do it not wait for a s/o for 2 weeks.
Date Posted: January 07, 2007 at 12:25 AM
I usually have them in stock. If I dont, then I can usually get them in 2-3 business days.
Date Posted: January 07, 2007 at 1:19 AM
wat site? or comp?
Posted By: elicoleman
Date Posted: January 09, 2007 at 11:28 AM
https://www.parrotkits.com/
Has anyone ever tried to locate the mute using the test light method on a 2007 GM? Why do we need to use that $100 harness if we tap the speakers after the amp and hook up the mute to the stereo. I still don't understand why this would effect the data bus system.
2003 GMC Yukon, Kenwood 815DVD w/ Nav. Memphis speakers. Kenwood 1200W Amp, Alpine 400W amp. Rear view camera, headrest monitors. Parrot CK3100
Date Posted: January 09, 2007 at 1:29 PM
You can still tap after the amp...but do you really want to void someones warranty?
Date Posted: January 09, 2007 at 4:45 PM
I don't know how the warranties work from state to state, but in California the car manufature needs to prove the modification likely caused the damage to the part in question for the warrany. i.e, if the transmission goes out, tapping into the speaker wires for a hand free kit likely did not cause that. But, if you blew out your stereo system, then maybe. I used to be in the auto repair field and ran across this a few times. I lowered my 2003 Yukon 6 months after I bought it (which everyone told me it would void the warranty) then I had a defective spring suspention item afterwards, that was not involved in the lowering  they covered 100% by the warranty. Other states, I do not know, but I do know alot of the warranty void myths are urban legends in CA. I would talk to someone knowlegable at you dealership and get the truth. (not High school Billy working for minimum wage
Good luck, and happy installing
Date Posted: January 09, 2007 at 5:02 PM
Back to my original question,
What is the reason for the expensive harness Cell Site has for the 2007 GM's. Lets take warranty voids out of the picture. If I was installing a Parrot into a 2007 Tahoe with Bose, on-star, nav ect... why can't I tap into the speakers after the amp, find both powers and ground? Does the mute for the stereo effect the data-bus system? That is the only thing I can think of but I don't know how it could possibly do so.
By the way, I am glad to see more people using the Hands free section of 12volt.com. It was a desert for a while.
Date Posted: January 09, 2007 at 8:32 PM
I havent tried tapping after the amp in this car, so im not sure what sort of issues may arise. In this field, I tend to play it safe. I am insured but I prefer not to butcher someones vehicle by cutting wires unless they sign a waiver releasing me of all liability. Oddly enough people will spend the extra money on the harness if they want it done right. The 07 harness for chevy/gmc's is 2x as much as the previous harness, but in my opinion it is well worth it. The sound quality is excellent and you still retain full control over the on star system. As far as warranty issues.....if the audio system decides to take a doodie....even if it is a burnt out light bulb on the radio face...I GUARANTEE you the dealership will blame it on the handsfree install. I have been doing this for 16 years and I have had only a few instances where the dealership has tried to blame it on me. Everytime I have been able to prove that my install was not the cause. If a dealership can get out of paying for warranty services..THEY WILL!
Posted By: Ppagliai
Date Posted: January 09, 2007 at 9:38 PM
Point well taken, customautomotiv, but I do have to agree with elicoleman...what makes this harness so expensive?  Afterall, all I am needing is one full time hot, one ignition switched wire, a ground and a mute wire connection.    I have a external speaker, so there is no need to tap into the stereo.  Does the Parrot harness offer more features than I need (or am I missing something?)
I had a harness for my '03 Avalanche that was called a GMCell or something like that.  It was about 25 bucks...I hate to be tight fisted about the price of the harness and I don't want to invade the factory wiring.
I guess I am looking for an elegant way to do this economically.....may not be possible!!??
Date Posted: January 09, 2007 at 10:10 PM
It was probably GMCSS-2 from cell site. There is now a GMCSS-3 for 2007+ GM's, that Cellsite told me, mocks the hardware in the radio. It is no longer just wires. It includes some harware. I am still in search af the answer what the hardware does. I would definitly be leary of not using the harness on a 2007 GM vehicle. I don't know what would happen if you tapped the mute on the radio, or cut the acc power (using relay mute method) to the radio while the car is running. It may trigger a check engine light or worse.
Customautomotiv: I understand your point, I do use harnesses most of the time. (all the time on Ford and GM). But I recently bought a harness for a 2004 Lexus from quickconnect and all it did for me was 12+, Gnd, and mute. I had to locate 12acc and run the speaker wires after the amp. That paticular harness saved me about 3 minutes of install time and added $50 to the customers bill. Not worth it. Cellsite harness are great for factory system installs. I use them alot. I wish they would move beyond GM and Ford.
Date Posted: January 09, 2007 at 11:36 PM
The new harness from Cell site does have an electronic box that has dip switches that must be set depending on the vehicle and if you have onstar. It is much like the interfaces you have to use when installing an aftermarket stereo in some gm cars.....chime module/bose interfaces. If you would rather do the work and cut wires...by all means go ahead. I havent had any issues with customers balking at the 150 bucks to do it the right way. I guess thats what you get in california...to many people with to much money. The majority of my customer base will not want the option of chopping into their factory wiring, they would rather pay the extra cash for the harness. Probably the easiest car i have done is the corvette. The amp is under the passengers floor board. That is about the only car I will splice into. Ford's are a piece of cake too....you dont even need the FCSS-2....you can push wires through the molex plugs on the back of the radio......and charge the customer the same as you would for the harness.....but no overhead!
Posted By: Ppagliai
Date Posted: February 10, 2007 at 2:42 PM
Hi Folks,
I did end up purchasing the GMCSS-3  for the 07 truck.  I am very pleased...you will have to purchase the LOC-1 to address volume output issues if you want to run it the the speakers in the vehicle instead of the dedicated speaker.  That is a $5 item.
I did find the harness at www.AutosportStyle.com for under $100.
Thanks for all your help!
pp
Date Posted: March 08, 2007 at 10:52 PM
Hey Customautomotiv
I would be interested in knowing how you push the wires through on Fords. Do you use terminals on the wires? I hate having to buy harnesses for everything. Thanks!
Date Posted: March 09, 2007 at 11:26 AM
I take 18-20g wire and strip off about 2 inches of insulation, I then push the wire through the empty slot and feed it through the other end. Once I have a little wire poking through the other end I bend it upwards so that it stays clear of the other pin holes. I then push the molex plug back into its housing. Thats it! Nothing to hard for anyone to do.
Posted By: jlsmobilesound
Date Posted: March 13, 2007 at 5:06 PM
Couldn't you also make relay to interrupt the stereo and mute it when you get a call? I installed one of these Motorola HF850 kits for a 2004 GMC Yukon Denali and we didn't do the mute deal because the customer didn't want to wait around. But anybody ever do a "relay" type interrupt? And this harness from parrot also does the job fine - never heard of complaints.
Date Posted: March 13, 2007 at 5:12 PM
Denali has a mute input in the radio.
