Steady Turn signal wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10272
Printed Date: April 22, 2026 at 6:05 AM
Topic: Steady Turn signal wire
Posted By: sammy004
Subject: Steady Turn signal wire
Date Posted: March 01, 2003 at 7:42 PM
Can someone please give me some in deapt info on getting a steady live wire from my turn signal. I found something in the misc. sec. under pulse to steady output from this site but I need more info on some of the stuff.
https://www.the12volt.com/relays/page5.asp#pts
Posted By: Two_Cold
Date Posted: March 01, 2003 at 9:00 PM
If you go as close to the turn signal switch as possible. Before the "flasher relay" the power should be constant. Look up your car on this website and see if there is a wiring chart with correct color.
Posted By: sammy004
Date Posted: March 01, 2003 at 10:11 PM
I tried that I have a 97 chevy Z71 and there is no wire before the flasher like it use to be on the old cars it's all computer chiped and stuff
Posted By: securinu
Date Posted: March 02, 2003 at 8:26 AM
what are you trying to do maybe we can figure something out if you let us know what you are trying to do
Posted By: sammy004
Date Posted: March 02, 2003 at 6:49 PM
I have a side marker from eurolight and it has 3 fuctions on it a stedy LED non-flash, Flashing LED, and side to side scanning mode. what I am tring to do is hook up the steady mode to my lights so when i turn my lights on they go on however when i turn the signal light on I want it to go in the scanning mode when signal is off its back to normal on I figured it all out and something on this site i found usefull as well i just dont know what a 10k fixed resist is or a 10k uf capacitor and how to det a diode in between 86 and 85 as seen on this page.
