dual colour illumination switch.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115145
Printed Date: May 05, 2026 at 11:32 PM
Topic: dual colour illumination switch.
Posted By: wayne23
Subject: dual colour illumination switch.
Date Posted: July 17, 2009 at 4:42 PM
I'm looking for a place where I can buy a dual colour illumination switch, color doesn't matter. Just to clarify green when off and when you turn it on it goes red, same idea as the ford upfitter switches. I want to either buy them or learn how to modify a normal illimination switch to make what I'm looking for.
Posted By: i am an idiot
Date Posted: July 19, 2009 at 3:51 AM
I have never seen a switch dual color illumination. This will be very easy to accomplish with 2 external LEDs that you could mount next to the switch. If this is acceptable, I will be happy to draw you a diagram. I just need to know if you are planning to switch Positive voltage or Ground? Are you planning to use a Pushbutton, toggle or rocker switch?
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: Ween
Date Posted: July 20, 2009 at 7:07 PM
hi, mouser...mountain switch...103-0006-EVX... $ 4.62 m
Date Posted: July 20, 2009 at 7:30 PM
https://www.mouser.com/Search/Refine.aspx?Keyword=103-0006-EVX Now I have seen such an animal. A sketch of one, but close enough. ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: wayne23
Date Posted: July 21, 2009 at 10:16 AM
Thanks guys thats what I wanted.
