freezing blinkers/hazard lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115535
Printed Date: May 05, 2026 at 7:53 PM
Topic: freezing blinkers/hazard lights
Posted By: imupabove
Subject: freezing blinkers/hazard lights
Date Posted: August 08, 2009 at 11:55 PM
i have a 93 camry. whenever i used my blinkers they freeze. mostly my left blinker freezes more than the right, especially when im at a stop light. and sometimes it blinks once and it freezes. its really annoying because i have to see if my blinkers are working so the people behind/side me can see im about to turn or change lanes. also my hazard lights freeze too. they dont even blink once. anyone know what is going on? thank you.
Posted By: i am an idiot
Date Posted: August 09, 2009 at 7:04 AM
Are the blinkers OEM or did you change them to LEDs?
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: yimke
Date Posted: August 09, 2009 at 9:28 AM
Change the relay. The time controlled circuit is most likely bad.
Date Posted: August 09, 2009 at 1:14 PM
they are OEM. i didnt change anything. they are stock headlights.
Date Posted: August 09, 2009 at 1:15 PM
what is the relay? where can i get that?
Posted By: yimke
Date Posted: August 09, 2009 at 11:59 PM
You should have a relay under your dash somewhere. More than likely in the Fuse panel area. Only remove the one that is designed for the blinker system. You could probably look up the location on a toyota forum.
Then take the relay to an auto parts place for a replacement, or see if they can test it. Should only run around $10.
Date Posted: August 10, 2009 at 12:44 AM
can i do it myself? so im going to replace some kind of fuse? where can i get it?
