Neon Music Interface
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1158
Printed Date: March 22, 2026 at 8:00 PM
Topic: Neon Music Interface
Posted By: ih8u37
Subject: Neon Music Interface
Date Posted: June 06, 2002 at 4:19 PM
Hi. I want to know if anyone with neon wiring experience can help me. I want to wire my StreetGlow Music Interface box so that the neons connected to it will turn on with the switch on the box, but also when I open my doors (replacing the dome light, kick panels lights, etc.). Please post if you have any suggestions, I've already fried one box trying to figure it out. Thanx.
Posted By: Thinkster
Date Posted: June 07, 2002 at 2:42 AM
First, what is the "Music Interface box" and I take it this box has a built in ON/OFF Switch or is it external???
Posted By: ih8u37
Date Posted: June 07, 2002 at 6:35 AM
Sorry I didn't give much info. It's a product made by StreetGlow which has one ground wire, & one power wire w/ an inline fuse that connects directly to the battery. On the back, it has four + and - connections, which you can connect any neon lights to (as long as they don't exceed 5 amps). The box has 3 built in controls, an on/off switch, a light/music switch (allows you to just have all the lights on, or bounce to the music), & a sensitivity control for when the second switch is turned to "music". All the switches are built into the box. Thanx in advance.
