steering wheel led
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116747
Printed Date: May 07, 2026 at 12:34 AM
Topic: steering wheel led
Posted By: amh9002
Subject: steering wheel led
Date Posted: October 05, 2009 at 11:42 PM
Hi all,
I am currently in the process of trying to make a custom steering wheel center emblem for a 2008 Mustang. I am casting it out of clear resin and then painting everything black except  the very outer edge. In theory, since it is clear, if I were to put an LED behind it, it should light up the ring that was not painted. The problem I am having is coming from how to wire it. I know about resistors and all that good stuff, but it is going to be an RGB LED that can be tied into the factory installed ambient lighting system (7 color). It would be four wires and I know that just running them straight down the steering column could cause a potential snagging hazard. Is there any way anyone can think of doing this? I have thought about seeing if there is any space left in one of the wiring harnesses running to the clock spring but, I would rather not mess with it. Any ideas? Any help would be great.
Posted By: ckeeler
Date Posted: October 06, 2009 at 12:08 AM
it really has nothing to do with space left in one of the harnesses to the clock spring because the clock spring would still have to have the proper number of usable traces, or tracks on it. in order to work you would have to get rid of some of the OE wiring to the clock spring so that you can use yours in place of it, or harder yet, find a clockspring with an adequate amount of traces that will work in place of the original.
Posted By: amh9002
Date Posted: October 06, 2009 at 12:17 AM
any ideas on where to begin looking for a clock spring that could handle everything? ive searched up and down on google and can't seem to find anything
Posted By: ckeeler
Date Posted: October 06, 2009 at 9:18 AM
you might try to start hitting up wrecking yards and looking for late model cars that have lots of buttons and controls on the steering wheel such as radio functions along with cruise controls ect, or go to a good CARQUEST parts store and see if they will let you thumb through their DORMAN OE replacement part catalogs, you might spot something that way, but it's still gonna be a long shot.
Posted By: KPierson
Date Posted: October 06, 2009 at 12:06 PM
Most steering wheel buttons are multiplexed so there isn't a bunch of wiring.  You may have to go the same route as adding 4 seperate signals to the clock spring may be difficult.  If you could find a ground in the steering wheel already and could encode the three digital signals you can send them through on one wire and then decode them in the steering wheel.  I would imagine someone makes a simple chip that would do all of this for you.
The other alternative is RF.  I know they make very simple inexpensive digital RF chips.  if you could find power and ground inside the steering wheel you could make that happen pretty easy.
Kevin Pierson
Posted By: amh9002
Date Posted: October 06, 2009 at 1:25 PM
I'm liking the idea of the RFID theory. I'm sure I could find power and ground in the CC module buttons. A couple of questions though. Will RFID work to send out the apropriate signals from the led microcontroller? It's a seven color controller. If it does work do you know where I could find a RFID chip and transmitter? Or am I not on the same page as you?
Posted By: KPierson
Date Posted: October 06, 2009 at 2:22 PM
RF and  RFID are two completely different things - RF is all you need.
Do you have a wiring diagram for the existing switches?
Look in to this: Linx TXE-315-KH2 - this is a 315mhz 8 input encoder and transmitter (about $10).  You may need to add an antenna to get it's advertised 3,000 ft range, but for your 3' situation I doubt the antanna will be that critical.
Pair it with a Linx RXD-315-KH2 - this is a 315mhz 8 outuput decoder and receiever (about $16).
These are just two examples - you will need to do some reseach up front and may have to add some support circuitry.  For example, the transmitter above is designed for battery operation and has an input voltage range of 2.4-3.6vdc.  If you hook it up to the car battery you will fry it.  I'm not sure if there are 12vdc versions of these available, but I do know several companys make little RF chips like this.
Kevin Pierson
Posted By: amh9002
Date Posted: October 06, 2009 at 6:06 PM
Ok I looked into it and it looks like a great idea and I want to try it out. The data sheet says it will need a dip switch to set the address so Im a looking for a mounting location that will have enough space for the dipswitch, rf module and wires. Any ideas on where I might be able to do that?
