strobe light for reverse light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120812
Printed Date: March 23, 2026 at 9:50 AM
Topic: strobe light for reverse light
Posted By: phamstarr
Subject: strobe light for reverse light
Date Posted: March 19, 2010 at 1:52 PM
Hello, I was wondering if I can get any tips or instructions for installing strobe lights as reverse light. Any help would be greatful. Thanks
Date Posted: March 19, 2010 at 1:54 PM
Sorry. I have a 1999 Civic Hatchback DX
Posted By: oldspark
Date Posted: March 19, 2010 at 5:14 PM
Illegal (I should think).
And I would argue highly NOT recommended.
If you strobed me, I'd be likely to react in a very aggressive manner.
And I do not "suffer" from strobes as some do.
Posted By: jeremytravis
Date Posted: March 20, 2010 at 12:58 AM
Well, https://strobesusa.com has some prety cool kits, the installation process will vary, but should be relatively simple. ------------- **ADVANCED MECP CERTIFIED
Date Posted: March 20, 2010 at 9:04 PM
I installed it yesterday, but I think I got the wiring mixed up. I wanted the strobe light to ONLY come one when I reverse. When I installed it, the strobe light didn't turn on until I turned my headlights on and the strobe stayed on. Thanks for the website but I didn't find anything on that website to help out. Do you know what I'm wiring wrong? Thanks
Date Posted: March 20, 2010 at 9:50 PM
Well it sounds like you connected then to the wrong wires (headlight circuit) , you need to find the reverse light wires, what kind of vehicle is it? ------------- **ADVANCED MECP CERTIFIED
Date Posted: March 21, 2010 at 10:08 AM
I have a '99 civic hatchback DX. I connected the power supply to the black and red wires in the tail lights. The kit I got was from Ebay. (Yes, I know, it's cheap)
https://#/12v-Adjustable-2-bulb-5-color-Strobe-Light-Kit-WI-200_W0QQitemZ380215409947QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item58869abd1b
The color wires that powers the reverse light is green and black. should I run the power supply supply from the strobe directly to the car battery with a resistor (If so, what kind and amp), and the ground wires to the black wires in the back? Thank you for your assistance.
Posted By: t&t tech
Date Posted: March 21, 2010 at 11:14 AM
Resistor? Car battery? Don't you want it to come on with reverse, you've already deciphered the colour, so connect the positive lead of the strobe to the GREEN/ back and ground the other lead and you're set! -------------
Date Posted: March 21, 2010 at 11:59 AM
Thanks T&T for your helpful advice. The two wires that powers the reverse lights are green and black. I'm guessing green would be power and black would be ground. I am ggoing to try your advice and hoping that it will end my search for Q&A. I will kepp ya'll posted but please don't stop more helpful advices because after searching and searching, there are some people that connect their strobe light power supply directly to the car battery and ground the ground wire to the chasis. So more advices is greatly appreciated and thank you 12volts members!
Posted By: t&t tech
Date Posted: March 23, 2010 at 3:37 PM
Oh green and black! I just re-read, well if these are the two wires entering the socket at the reverse bulb, then yes, green will be power and black will be ground!
