extend courtesy light time
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123101
Printed Date: March 22, 2026 at 1:21 AM
Topic: extend courtesy light time
Posted By: jdugan4859
Subject: extend courtesy light time
Date Posted: August 12, 2010 at 9:00 PM
I have a 2011 Hyundai Sonata, and the courtesy lights only last 15 seconds, which is way to short. Wondering if there is any way to extend the time limit using a Pac TR7 or a DEI 528T relay, or anything else. Also what would I need to do, is there a separate circuit or how does that work?
Posted By: oldspark
Date Posted: August 12, 2010 at 9:25 PM
They were a circuit that could be modified if you know how.... (In 1980s & 1990s Jap cars they were often a module in te relay/fuse box etc.)
If they included dimming, they'd be harder to modify (the lamp load can vary the dimming cycle/delay).
These days they may be ECU controlled....
