db all firmware
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126631
Printed Date: May 10, 2026 at 12:57 PM
Topic: db all firmware
Posted By: jseibold
Subject: db all firmware
Date Posted: March 19, 2011 at 6:27 PM
Car:  09 Chevy Cobalt
Remote Start:  APS687
Bypass:  DB-ALL
Problem:  The DB-ALL will not program to the car.  I do not have the flashing module to update the firmware and the manual says I need the GM5 firmware.  I double and triple checked all of my connections and everything is wired as per the DB-ALL manual.  I have done these cars before but I have used a DLPK for the last few and now the DLPK has been discontinued.
My question:  Should the DB-ALL have the GM5 firmware right out of the box or does it have to be flashed?  The distributor that I buy my equipment from did not think it should have to be flashed but he wasn't positive.  I of course went for it without flashing the module first.
Posted By: jseibold
Date Posted: March 22, 2011 at 10:31 AM
Has this been covered somewhere else in the forum?
Posted By: jseibold
Date Posted: April 19, 2011 at 9:29 AM
To answer my original question regarding the DB-ALL...
I just wanted to communicate this to those of you that have not yet used the DB-ALL.  You must have the XK-LOADER2 and flash the DB-ALL with the correct firmware for the car you will be using it in.  The DB-ALL comes out of the box preloaded with one version of Chrysler firmware.
