pop when turning of light switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128302
Printed Date: May 13, 2026 at 10:09 PM
Topic: pop when turning of light switch
Posted By: t&t tech
Subject: pop when turning of light switch
Date Posted: August 21, 2011 at 11:44 AM
So I did some lights on a 2009 nissan navara recently, a significant amount I might add, underbody, rotor, interior the whole nine yards, anyway, I wired them via a toggle switch and a relay, now my problem is, when the guy uses the switch and his audio is on when he turns off the light switch, he gets a pop through the mid range speakers, it was never there before, he has two amps, a 4000 watt class d exterminator and an 800 watt four channel for the mids and tweets, using a pioneer 500 ub head unit and a soundstream pre-amp.
Any suggestions as to what might cause this, I didn't interfere with any wiring at the amps or anything to do with the audio, so I really don't know how the issue arose. Any possible solutions or suggestions as to what i can do to remove this would be appreciated, I have not done any trouble shooting yet,since he has'nt had time to return, but he will be back soon, just want a heads up as to what to look for. Thanks in advance.
Posted By: i am an idiot
Date Posted: August 21, 2011 at 2:35 PM
https://www.the12volt.com/relays/page5.asp#ctm
Use the above link only to see how to position the diode across the coil of your relay. A diode is a polarized device.  It has to install across power and ground to the coil of the relay.
Posted By: t&t tech
Date Posted: August 21, 2011 at 7:48 PM
That simple huh, I will try it and post back.
Date Posted: August 21, 2011 at 8:22 PM
Yup, it really is THAT simple.
Posted By: t&t tech
Date Posted: August 22, 2011 at 3:55 PM
Hey IAAI, i have another problem with the same vehicle where the clock in the tachometer keeps getting thrown off everytime he switches the vehicle off and on again, any suggestions.
Date Posted: August 22, 2011 at 4:47 PM
Define "Thrown Off". Does it reset to 12:00 or 1:00 everytime you power the key off? Or does it just lose the time that the key is off for?
Posted By: oldspark
Date Posted: August 22, 2011 at 8:55 PM
If it's a reset as Sir Idiot Esq. is asking, that clock should have its own constant power feed as opposed to the switched power (IGN) for the tacho.
Date Posted: August 25, 2011 at 8:00 PM
Did you get the popping noise to quit?
