third brake light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129386
Printed Date: May 13, 2026 at 4:27 AM
Topic: third brake light
Posted By: anderson2624
Subject: third brake light
Date Posted: November 25, 2011 at 8:46 PM
Can someone point me to a place here where I can get info on installing my "owned " light as a third brake light on an older car? (not a JC Whitney after market)
thanks
------------- gene
Posted By: i am an idiot
Date Posted: November 26, 2011 at 3:46 AM
Do the brake lights on your older car do double duty as the turn signals?
Posted By: jseibold
Date Posted: November 26, 2011 at 12:30 PM
Your existing tail light's brake wire circuit probably does double duty as turn signals. To make your light work properly, you will likely have to tap the cold side of the brake switch near the brake pedal and then run a wire from there to your 3rd brake light. It would help if we knew what kind of car (year, make, model) you are installing into? -------------
Date Posted: November 26, 2011 at 1:17 PM
I should know better... 62 Ford Falcon. I was hoping to not have to run a wire from the cold side of the brake as suggested. Turn and stop lights do double duty. Wanted to hook something up at the rear deck.
thanks again this site is awesome
------------- gene
Date Posted: November 26, 2011 at 1:28 PM
It can be done at the back deck, but you will still need to run a power wire to the front of the car. It will be much more complicated, requiring diodes and relays. So since you will have to run a wire to the front, just run it to the cold side of the brake switch.
