wiring up led lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130081
Printed Date: May 13, 2026 at 12:44 AM
Topic: wiring up led lights
Posted By: tawny owl
Subject: wiring up led lights
Date Posted: January 06, 2012 at 4:47 PM
Hi all ,
I have just installed some led lights into the front bumper , I have wired them into the sidelights as I don't want them on all the time like day running lights.
What I am looking to do is have these led lights switched off when I put the headlights on but can't for the life of me work out how to wire the relay up to do this as the side lights remain on with the headlights .
Would really appreciate any advice on pin configuration on how to do this.
Kind Reards
Tawny
Posted By: oldspark
Date Posted: January 06, 2012 at 5:30 PM
Connect the LED grounds to the headlight (or beam) +12V supply. (Via diodes to hi & low beams if a "beam" +12V is not available.)
Date Posted: January 07, 2012 at 2:19 PM
Thanks , in the end I wired it like this
Pin 30 Side light
Pin 85 Earth
Pin 87a DRL power
Pin 86 Headlight feed
Posted By: oldspark
Date Posted: January 08, 2012 at 2:43 AM
The relay is uneccessary if wired as I described.
Posted By: youngfish
Date Posted: June 12, 2012 at 5:47 AM
Does anyone know any brands of small attachable LED lights for a small HD video camera. It's an 840HD vivitar. Its not anything big, But it's just for some small footage, but for filming at night - I was wondering if an LED light would do the job, because the camera doesn't seem to have any night lighting available?
Posted By: nev main
Date Posted: August 03, 2012 at 7:34 PM
Hi,
How can I wire LED running lights on an ix35 to come on and off with the ignition
running lights ------------- running lights
Posted By: oldspark
Date Posted: August 03, 2012 at 7:39 PM
Wire then across IGN +12V.
Posted By: nev main
Date Posted: August 03, 2012 at 7:43 PM
Thanks,
Will give it try
running lights
Posted By: vinchinzo
Date Posted: October 23, 2012 at 12:24 PM
get some christmas lights and run them all around your car under the fenders and hook them up to a toggle 12v constant lol My dad told me thats what they did back in the day! lol
------------- When in doubt....kick it!
