2001 taurus dash lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131130
Printed Date: May 13, 2026 at 6:22 AM
Topic: 2001 taurus dash lights
Posted By: 1967-68-bird
Subject: 2001 taurus dash lights
Date Posted: April 06, 2012 at 10:49 AM
erratic behavior with headlamps on.the dash lights will go off and on sometimes will last hours other times minutes. however when the dash lights turn off, both the turn signal indicators will come on at half their brightness.and at one time when the dash lights were off i hit the turn signal lever and the center dash (radio,heater,etc)lights started blinking with the flasher. I suspect a bad ground but where should i start
Posted By: astra1397
Date Posted: April 10, 2012 at 8:45 AM
Look around in here and see what you can find to help with this problem.
taurus club
