music pulse led’s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133987
Printed Date: March 20, 2026 at 6:10 AM
Topic: music pulse led’s
Posted By: slg2021
Subject: music pulse led’s
Date Posted: April 05, 2013 at 2:24 AM
Hi, I have blue 12 volt led tubes on my boat, with just a positive and negative wire, and i want them to pulse to music coming from my radio. I can't find a good way to do this cause i want it a certain way, so if anyone can help me it would be appreciated.
I want to have blue only plusing to music
No mics, i want it to be hard wired like an aux or rca plug
12v
all i can find is rf rgb audio controllers with a aux plug, which i bought, it works but for rgb so it looks stupid trying to power just blue lights
i also have seen this:
https://www.instructables.com/id/E1K7SJ2ZG6ERIE36TP/
but my only question is could that power as many led's as i have and is there a way i can add a sensitivity adjustment to it?
Posted By: oldspark
Date Posted: April 05, 2013 at 8:44 AM
Try connecting the strings across the speakers.
If the output is under 200W (into 1 Ohm), 12V LED strings will be fine.
Posted By: slg2021
Date Posted: April 05, 2013 at 12:38 PM
but then the volume of the radio effects how much they pluse
Posted By: oldspark
Date Posted: April 05, 2013 at 5:39 PM
Isn't that what you want - ie, they pulse to the music?
