Two Lights w/Switches + 1 Dimmer + Switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144238
Printed Date: April 22, 2026 at 5:20 PM
Topic: Two Lights w/Switches + 1 Dimmer + Switch
Posted By: robertrhu
Subject: Two Lights w/Switches + 1 Dimmer + Switch
Date Posted: March 18, 2018 at 11:01 PM
Hi all...
In the midst of rewiring a travel trailer. I’m new to electrical work. I’ve gotten the hang of the basics. But I’m stumped on this problem...
I have two lights, each with an in-line rocker switch.
I’m wanting to add a dimmer switch that will control both lights at the same time, while still being able to shut off each light individually using the inline rocker switches.
I’d also like to have another rocker switch that will shut off both lights from the side of my bed without having to get up and use the dimmer or individual light switches. Asking for too much? 😉
I’m assuming I need...
1. Three SPDT ON/ON switches
2. The dimmer switch
How does this get wired up? Also, am I right about which rocker switches I need?
Any guidance would be greatly appreciated.
Thanks in advance!
Robert
Posted By: eguru
Date Posted: March 19, 2018 at 7:11 AM
Are you wanting to turn the lights off and on from the bedside switch regardless of the position of the two rockers? Or just turn both lights off if eother of the two rocker switches is ON?
Date Posted: March 19, 2018 at 4:52 PM
Ideally I would be able to turn the lights off/on from the bed side regardless of the switch position on each light.
Then a dimmer switch on the wall to control brightness.
Posted By: eguru
Date Posted: March 20, 2018 at 5:33 PM
Give this a go.
