Factory Fog Light Switch, 2009 Buick Lucerne?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144240
Printed Date: March 22, 2026 at 2:44 AM
Topic: Factory Fog Light Switch, 2009 Buick Lucerne?
Posted By: 96-vortec@15psi
Subject: Factory Fog Light Switch, 2009 Buick Lucerne?
Date Posted: March 19, 2018 at 3:52 PM
The factory switch sends out a momentary signal. I need to convert the momentary signal to a constant. Do I use a locking relay? What would be a good part number for a relay if this will work?
Date Posted: March 19, 2018 at 3:53 PM
2009 Buick Lucerne
Posted By: i am an idiot
Date Posted: March 19, 2018 at 6:41 PM
Do you need it to turn off with another pulse. pr when the key is turned off?
Date Posted: March 19, 2018 at 7:07 PM
It would be nice to turn off with the same pulse switch but not necessary.
Date Posted: March 19, 2018 at 9:33 PM
Date Posted: March 20, 2018 at 11:43 AM
Is there a part number for a locking relay that would work for my application? If I go with the multiple standard relay what size diode, 1 or 2 amp?
Posted By: eguru
Date Posted: March 20, 2018 at 5:32 PM
This might be a more flexible solution for you.
https://pac-audio.com/catalog/specialty-items/tr7
Date Posted: March 20, 2018 at 7:07 PM
This looks like the route I’m going to use. I will let you know, thanks for the help!
Date Posted: March 23, 2018 at 10:25 PM
The PAC Tr7 works perfectly for my application. Thanks for the info.
