install a windshield washer neon light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15036
Printed Date: March 28, 2026 at 3:32 AM
Topic: install a windshield washer neon light
Posted By: king_preetham
Subject: install a windshield washer neon light
Date Posted: June 16, 2003 at 6:26 PM
Hi,
I purchased a windshield washer neon light and am looking at installing it on my 99 toyota celica. I am new to installing stuff and wondering how(where) i could connect the 12v wire of the neon light to. I have looked thru my car manual and am unable to find the answer. I am looking to connect the wire such that it goes on when the light switch is turned on.
Appreciate the help.
Thanks,
Preetham.
Posted By: xetmes
Date Posted: June 16, 2003 at 6:53 PM
you could hook it to the wires going to the lights therefore when the lights are on they will be on, I still advise not putting these things on tho.
Date Posted: June 16, 2003 at 7:00 PM
why??, could it couse some problem....
How can i hook the wire to the light wire, i know that the ba\lack wire is the ground, the red wire goes to the light wire. but i am unable to find the light wire, probably im not looking at the right place. once i find the wire, how can i connect it to the wire.
Posted By: Maxima10to1
Date Posted: June 16, 2003 at 7:24 PM
Hook it to the side marker if you realy want it to come on with the lights. This is what i did with a 92 celica, but the cops dont like these lights so id run the lights on their own switch so you could shut them off. You can get power off the fuse block or cigarette lighter and ground anywhere you like.
Date Posted: June 16, 2003 at 7:44 PM
Can i split the wire comming into the side marker, i see 3 wires, a green with a yellow strip, a white with a black strip and a green wire, im gussing that i can use either of the green wires....
how can i get power off the fuse..all i see in the fuse bix is a set of fuses...
Posted By: xetmes
Date Posted: June 16, 2003 at 7:47 PM
you got a voltmeter? I dont know the wire colors but you could easily just check for the hot wire. good luck
Posted By: MAXST
Date Posted: June 17, 2003 at 5:03 PM
I recommend not hooking them up in junction with the headlights-so they on when the headlights are on...
   you will get pulled over and ticketed....
Its goes along with undercar neon.  Like on all those products say-- USE FOR OFF ROAD ONLY.
They are kewl though...
I need quality equipment, feel free to donate.
