neons
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15765
Printed Date: March 28, 2026 at 4:24 PM
Topic: neons
Posted By: 01Accord
Subject: neons
Date Posted: July 02, 2003 at 12:29 AM
i have a '01 accord coupe. i wanted to hook up two 15" tubes onto one 3-prong switch. i already tried hooking both neons to the climate control power wire, but it blew a fuse. i don't want 2 blow another fuse or drill 2 get 2 the battery. is there any1 who can help me hook dem up.
------------- Deep
Posted By: chevylove
Date Posted: July 02, 2003 at 12:52 AM
Search through the forum, there's like 20 posts dealing with that topic.
------------- Drew "Fuses are only 10 cents...go for it."
Posted By: Blazermedic
Date Posted: July 02, 2003 at 12:03 PM
Tap a fuse to get the power for the tubes, then give the power to the "12+" marking on the switch, ground the switch where it says "Gnd", and the run the "ACC" wire from the switch to your tubes, being sure to individually ground the tubes. Also, always fuse your power lines. Neons rarely draw more than 2 amps each (and that's being generous), so make sure you have the proper fuses in your power lines.
Posted By: Monkey2674
Date Posted: July 23, 2003 at 9:30 PM
Neons draw about .5amps each.
