H4 style bulb wiring hookup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15961
Printed Date: March 28, 2026 at 9:11 PM
Topic: H4 style bulb wiring hookup
Posted By: FirebirdStud
Subject: H4 style bulb wiring hookup
Date Posted: July 06, 2003 at 10:52 PM
I have a 95 firebird that I did a headlight conversion to.  I put in the H4 bulb, but how do you know how to hook it up?  like which connector is ground, high and low??  thanks for your help.  the connector looks like this "  | _ |  ".
Cody
Posted By: hotrodelectric
Date Posted: July 07, 2003 at 12:08 AM
Cody- on that style of bulb the "_" is low, and I forget which one is coded high, but a bulb doesn't care where power and ground go, so either one of "|" can be the high. However, make sure it's that way for both sides. Lt green is high, tan is low.
