Wig Wag Headlights 2003 Silverado
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23976
Printed Date: May 01, 2026 at 9:19 PM
Topic: Wig Wag Headlights 2003 Silverado
Posted By: acoccoluto
Subject: Wig Wag Headlights 2003 Silverado
Date Posted: January 05, 2004 at 12:39 PM
Hi, are there any other Police installers out there?
     I need help negotiating a wig wag system into a 2003 chev 1500 pickup.  In the past I have resorted to simply installing a st of halogen bulbs in the light housings for lack of a better solution, however my current customer would like to see if it is possible to get the traditional headlight flash with high beam interupt.  If anyone out there has encounterd this please reply.
Thanks,
     Allan
Posted By: jdc580
Date Posted: January 07, 2004 at 7:38 PM
if you want to do it right, then you need to order or pick-up a headlight flasher.  Once you have the flasher it will have instructions that are very easy to follow.  If you have any problems, I can help, but I need to know what flasher you are using.
-John
