Turn signal problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40607
Printed Date: May 05, 2026 at 9:02 PM
Topic: Turn signal problem
Posted By: sexican
Subject: Turn signal problem
Date Posted: October 09, 2004 at 11:00 PM
OK i was checking out my alarm system in my 98 blazer and i moved a couple wires around but then put everything back together.  I started driving and i noticed my turn signals werent flashing outside or  inside. i got off and looked at the fuses and the siggaret lighter fuse was busted, i go to get my fuse tester and i try to check the fuses in the inside and every fuse causes a spark.   does any one know what the problem could be ( i have to push the hazard button like 3 times in order for it to turn on and it also turns off.)
any help would be great
LEO
Posted By: hurtado_roberto
Date Posted: October 11, 2004 at 12:30 PM
When I was installing my system I don't remember messing around with wires underneath the instrument panel buy my blinkers went out about a week afterwords.  I think is was a factory defect on my 04 hyndai, but if could have been be messing around with the electrical system.  I took it in for an inspection and they checked the fuse, flasher relay, flasher modual, and flasher switch only to find a loose wire on the flasher switch.  When I was driving home I noticed that they still didn't work.
The second time I took it back they ordered a new turn signal switch and solved the problem.  You should check all the parts I mentioned if you know how using  a multimeter.  Why did you say that every fuse causes a spark?
Poly Dollies
Posted By: SEXIFIED
Date Posted: October 19, 2004 at 6:28 PM
there is a relay on the passenger side under the hush panel held on by 6-8 #7mm screws. it is a flasher relay i had a buddy that had the exact same problem go to the dealer
Posted By: sexican
Date Posted: October 19, 2004 at 10:04 PM
ok cool guys thanks for the help hey CHeck out the names
LEO
