smoked a fan controller
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57239
Printed Date: May 06, 2026 at 9:12 AM
Topic: smoked a fan controller
Posted By: danieljaluise
Subject: smoked a fan controller
Date Posted: June 07, 2005 at 6:29 PM
I wired a fan controller, meant for a computer, to a couple fans I had on the amp rack. on the computer molex plug, you have yellow, black, black, red. I hooked the yellow to 12 volts, the first black to ground, and tested it. The fans powered up fine.   But the control was supposed to light up on the knobs. I know because it ran nice in my computer when I tested it. So, I decided to hook the red wire to 12 volts also..   BAD IDEA. Smoke went everywhere. The LED lights came on and were blinking. I pulled the fuse after a second or two. And then realized that the red wire must only get 5 volts instead of 12. Assuming that this still works, is there an easy way to get 5 volts to that wire, or should I just live without the controller lighting up>?
This is what I used:
Click Here
Thanks,
Dan
Date Posted: June 08, 2005 at 3:09 PM
well, no responces. I guess i can use a DC converter. That's about te only way I can think of.
Posted By: Scuba_04
Date Posted: June 12, 2005 at 12:30 AM
What you need to do is put a 4.3V Zener Diode in line with the 5V wire. :)
Steve
Music Mart
Installer
