noise from hardwired neons
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62563
Printed Date: May 20, 2026 at 4:43 PM
Topic: noise from hardwired neons
Posted By: jlord16
Subject: noise from hardwired neons
Date Posted: September 12, 2005 at 4:46 AM
I have hooked up a neon (one of the ones that can "pulse" with the beat).  I have tried joining the + terminal to both the amplifer power and amplifer remote turn on lead.  I have also tried grounding the amp and neon in the same place or different places but i still get noise.  The neon is about a foot away form the 1200watt amp and the subwoffer is also about a foot away.  The sub reproduces static when the neon is connected reguarless of how it is connected.  Would it be better to wire it off the battery?  I have a 4-8AWG distribution block.  Im running 8AWG power to the amp, can i run 16AWG wire to the neon through the 8AWG block or would i be better sticking with 8AWG power throught.  Or can i alter the wiring from the amp to stop the noise/static
Any ideas and input is greatly appreciated
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
Posted By: sneakycyber
Date Posted: September 13, 2005 at 11:58 PM
Don't hook the neon up to the amp.. run a seperate power line from your distribution block to your neon.. The transformer in the neon is whats causing the noise in your amp.
Posted By: jlord16
Date Posted: September 16, 2005 at 11:31 PM
Alright, so i wuld then have to put a switch in to turn the neon off wen the car turned off, or could i wire it in to the 12V accessories wire going into the head unit and and other parts of ther car?
Clarion DB36MP
Respone 800w Mono
ALPINE MRP-F250
Posted By: chido
Date Posted: September 20, 2005 at 3:09 PM
Try wiring it up to the back of the wire that goes to the lighter b/c it turns off when the car is off and if you want to toggle it on and off you could add a toggle switch to the (+). I did this and it worked out well. Wiring was a "B" cause hardwired 4 together and with a central pulse unit on a toggle.
