wiring distribution blocks?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64384
Printed Date: May 06, 2026 at 9:30 PM
Topic: wiring distribution blocks?
Posted By: niteskyy
Subject: wiring distribution blocks?
Date Posted: October 14, 2005 at 5:02 PM
can you had 2 distribution blocks.  I will just make a diagram.
subwoofers------------}\
                                         ----------amp----(4 guage....I think...)--------------distribution block--------------Car Battary(12V)
subwoofers------------}/                                        l                                                        l                                           l
        cd player                                              l                                           l
        l (negitive)                         l
(4x)Neons-----------------------------------------------------------------------------distribution block                            l
        l                                            l
        l                                            l
        toggle switch-----------------------l
        (positive)
Can you do that with distribution blocks???
I dont want to blow up anything if I install my neon lights like that.
p.s.  This was fun making this diagram.  It isnt perfect but you can somewhat get the idea.
Posted By: youngone
Date Posted: October 14, 2005 at 6:54 PM
that dosent look right.
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
Posted By: niteskyy
Date Posted: October 14, 2005 at 11:48 PM
I meant to say can you like hook 2 distribution blocks up like that.  I am sure the diagram is not exactly perfect in how to hook them up but can you use one distribution block and then put another one off of that one.  That is all that I am really trying to say.
Posted By: Hornshockey
Date Posted: October 15, 2005 at 10:03 AM
if I'm reading correctly, you've got a switch that leads to nothing and a direct short between the +12V and negative. Neither of those will get you where you want to be.
If all you're wondering is if you can run a single wire from the battery to one dist block, then split that wire again with another dist block? That's fine; just make sure the primary wire coming off the battery is large enough to handle whatever amperage you will be running through it. And you can use a dist block for your grounds; just don't connect it inline with your main power wire posted_image
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
