Neon light connected to car alarm system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65294
Printed Date: May 06, 2026 at 10:43 AM
Topic: Neon light connected to car alarm system
Posted By: larry2oo4
Subject: Neon light connected to car alarm system
Date Posted: October 30, 2005 at 11:31 AM
is it possible to connect my neon light to my car alarm system so i can be able to turn my lights on using my remote please help
Larry A Isaac
Posted By: chriswallace187
Date Posted: October 31, 2005 at 12:16 AM
It can be done fairly easily...how are your neons switched on right now?
C Renner's Auto Electronix
Date Posted: October 31, 2005 at 11:31 AM
i havent install them yet but if you can tell me how i will really appeciate
Larry A Isaac
Date Posted: October 31, 2005 at 9:50 PM
Assuming your neons just have a switch and not a control module, here's how you'd do it using an SPDT relay.
85 : - auxiliary output from alarm.
86, 87 : fused constant 12v +
30 : power feed to neons
87a : not used.
Posted By: konstantin
Date Posted: November 01, 2005 at 12:33 AM
I have only been playing with car lighting and relays for days, so someone please correct me if I am wrong.
I would install it like this:
posted_image
Intall Relay 1 in the engine bay, and Relay 2 in the car's interior
(1) Parking light input so you would not accidentaly turn your neon during the day
(2) A switch in the interior so you can turn it off, even at night.
Is this a correct diagram?
Konstantin
Date Posted: November 01, 2005 at 5:03 AM
I think I made a mistake.  With the above diagram, the neon will only light if the parking light is on.
Please review the following diagram, hopefully it would be right
posted_image
Konstantin
Date Posted: November 01, 2005 at 9:13 AM
The second diagram is good; however I wouldn't use the parking light output because there may be a time when you want just the neons on without parking lights, and neons don't draw much current at all where they'll drain the battery quickly. Your diagram is correct if you want to go that way though.
Also, you can generally find that parking light wire inside the car as well as under the hood.
Date Posted: November 01, 2005 at 11:01 AM
so i still have to connect the relay to the battery because i thought i just have to connect it to the alarm . also do i still have to connect the switch that came with the neon to the relay
Larry A Isaac
Date Posted: November 01, 2005 at 11:06 AM
so from the hardware i got can the multi-outlets power connector block be used as the relay
Larry A Isaac
Date Posted: November 01, 2005 at 10:01 PM
Chris is right, if we want the neon to light without the parking light, I would change the parking light input (1) into ACC input, so I won't forget turning it off when leaving the car (but Chris said neon consumes very small power anyway it won't flatten the battery).
How much power does a neon system draw?  Alarm module's negative output is normally around 200mA (designed for relay-driven functions), meaning the maximum power it can give is theoritically around 2.4W.  The switch is for when you want to turn on the LED without the remote.
To give you a picture: I connected the dome light output direct to a separate bulb, and it only lights very dimly.  I change the bulb to a LED around 2W, and it lights fully
