Best way to tap turn signals
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77729
Printed Date: May 08, 2026 at 6:58 PM
Topic: Best way to tap turn signals
Posted By: Jasonb61
Subject: Best way to tap turn signals
Date Posted: May 13, 2006 at 5:53 PM
Hello,
This is a universal question but just for reference I have a 92 Dodge Dakota. I just purchased some m3 sports mirrors with 3-color LEDS and I am going to use the orange led for a turn signal...
Anyways, I was wondering what the best way would be to tap into the turn signal... and WHERE... I really dont want to have to add 2 relays but if that's what is best then i will!
Thanks,
-Jason
Posted By: crcustoms45
Date Posted: May 29, 2006 at 4:06 PM
you should not need relays.
the easyest way to find/tap turnsignal, would be at the turnsignal lamp.  you will need a test probe (or dmm)  and 10-15 ft of 16-18 gauge wire.
a quicker install would be to find the wire at the steering column, depending on your knowledge.
to determine which wire is the turnsignal switched (+) wire,  probe a suspected wire and turn turnsignal on. it will reverse polarity every flash of the bulb.
email me if you have more qurestions, hope i could help.
Chris
CRCustoms
