Indicator Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78687
Printed Date: May 09, 2026 at 5:22 PM
Topic: Indicator Problem
Posted By: c110gtr
Subject: Indicator Problem
Date Posted: June 04, 2006 at 6:50 AM
Hi
My front indicator is not working properly, (parkers on front are same as the indicators) when you pull the switch to parkers on and right indicator on (drivers side) the light stays on it doesnt blink the passenger side goes off as normal.
When you put the left indicator (passenger side) it works fine blinks but the drivers side indicator stays on.
Rear indicators work fine, if the switch is pulled all the way to headlights on everything works fine.
The issue only comes when the parker lights on.
Any ideas how to solve the problem?
Posted By: c110gtr
Date Posted: June 04, 2006 at 4:36 PM
Its for a 1963 Datsun 1200 Pickup or N320 Series
