turn signal problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79319
Printed Date: May 10, 2026 at 4:49 AM
Topic: turn signal problems
Posted By: acopsy88
Subject: turn signal problems
Date Posted: June 19, 2006 at 8:46 AM
All right heres the scoop i have a 97 mitsu eclipse. i woke up and got in my car and notice the turn signal was blinking so i went to shut it off and it wouldnt shut off then i tried to turn it the opposite way left and had no effect. i checked my relays n fuses their okay, but if i turn my hazards on they both strobe at that any help would be great thanx adam
2 12 inch jl audio w3s stock infinity sound eclipse deck memphis 1000d
Posted By: djfearny2
Date Posted: June 19, 2006 at 10:57 AM
sounds like the turn signal shifter is messed up. maybe it got wet carroded or worn so it is no longer functioning properly i would look into changing it.
Jon
Installer/Help Technician
---coral springs florida---
Posted By: acopsy88
Date Posted: June 19, 2006 at 10:59 PM
ok my car is a convertible and it rained the night before so it is very possible thanx that all the possibilities adam
Posted By: Teamrf
Date Posted: June 19, 2006 at 11:40 PM
Oh my....those switches go out all the time. I had a sebring(same thing almost) I had to replace my switch twice. I have like six of those switches in my toolbox.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: acopsy88
Date Posted: June 25, 2006 at 2:37 PM
do you think it could be a flasher rel;ay also any ideas where i could get a new turn signal switch thanks adam
Posted By: acopsy88
