Blinkers flash fast with trailer?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80918
Printed Date: May 12, 2026 at 1:34 AM
Topic: Blinkers flash fast with trailer?
Posted By: scott ameline
Subject: Blinkers flash fast with trailer?
Date Posted: July 28, 2006 at 8:29 PM
How come when I plug in any light set up, trailer or boat, the blinkers flash super fast. If I un plug them it flashes normal?
Scottman
Posted By: ck auto
Date Posted: July 28, 2006 at 8:51 PM
you need a heavy duty flasher go to local autoparts place to get one remove old one install heavy duty one.  Problem solved the factory flasher can't handle the extra lights
good luck
kirk
Posted By: ff-mike
Date Posted: July 31, 2006 at 10:47 AM
Good advice- best choice would be an electronic flasher
